Hello everyone,
I was asked whether it is recommended/feasible to build a PV farm (in the range of 2 MWp) in the vicinity of a hot spring. I was told that there is presence of sulfuric acid in the air; (not sure about concentration but it should not be high; there is also a fully functioning hydro power station in the same area).
As far as my research went, sulfuric acid does not react with copper, but it does react with aluminum, so I am assuming dual glass solar panels are mandatory as well as a stainless steel mounting system? What about the coating the panel? Does sulfuric acid react and damages the coating of the solar panels? Does the panel need some other type of
